Daedalus
Gen3 noob
I'm having some trouble with a creaking and groaning sound from my rear window area. It's probably been doing this for some time, but it's about the only "bad" sound left after my suspension work, so it's been pretty noticable.
Suspension work was:
- Monroe QuickStruts all around
- New swaybar endlinks all around
- Everything else stock, as far as I know
I'm thinking it's probably my rear swaybar bushings. I also wondered if worn trailing arm bushings (I think that's what they are called - the large bushings on the rods that go from under the back seats to the rear wheels) would creak.
I can get the car to creak if I lift up on the driver's rear wheel well. It's an almost constant creaking and groaning on rough roads, not so bad on smooth roads. I also seems like it may be worse when it's wet outside.
