js139
So I was in replacing my crankshaft seal and CPS sensor when one of the screws holding the sensor in place broke off when I was removing it. I cannot get it out and am going to have to drill it out and use a screw extractor. Easy enough, however I can't get my drill in the compartment to perform the procedure. Anways, I am trying to remove the cover that holds the crankshaft seal, but I can't seem to break it loose. I feel like I am missing something with it. I removed the 4 bolts on the face of the cover and the 2 bolts from the oil pan that go into the cover. I have also used a puller and started to seperate it from the block, but only the right side wants to move. The left side acts as if there is still something holding it in place. Can someone that has done this before please help me out on what I need to do to break that cover loose to remove it? What am i missing? Any help would be great at this point.
Thanks,
Jeremy
Thanks,
Jeremy
