Crankshaft Pulley Installation
If you have a manual transmission, you can either have someone press ******* the brake pedal as you torque or you can put the space saver spare on the hub, lower the front end to the ground, put the shifter in fourth or fifth and toruqe away. If you have an automatic transmission, you can tighten a large C-clamp on the damper and let the bridge of the clamp press against the metal tab under the crankshaft. Be careful that the clamp is solidly attached to the damper and the tab.
