Crankshaft bolt torque rating?
Off Road SHO
Moderator
You only have ONE crankshaft bolt?
Are you referring to a bolt that holds something onto to the crank or the bolts that hold the crank onto something like a block?
Tom
freeze
tulsa
according to ford the crankshaft damper-to-crankshaft bolt is 112-127 ft. lbs.
The number I have ben using is 113-126 lb-ft. Close enough for government work.
hosbaldosho
