shobikes
Howdy y'all-
Yesterday while replacing my rod bearings and y-pipe, while the starter was out and all that, I noticed a crack in the subframe adjacent to the forward engine mount. It looks like it propagates from the trailing edge of the subframe, where the reinforcement crossmember is welded to the main subframe. The crack runs from that weld point upward and around toward the motor mount bolthole, stopping about 1-1/2" from the hole. It hasn't opened up, not showing any signs of deformation. I can't tell whether it's cracked from the stress of the motor mount or the tension arm of the lower control arm assembly.
So my question: Next Wednesday, it's going to the muffler shop for custom catback. The exhaust guy is a master welder and has already said he can run a bead up the crack to allow me to ignore it for a little while. I have an extra subframe I was hoping to not have to pull off the parts car, so now I guess I will, but I need to get another daily driver together before attacking this task. Do you think if I get the crack welded before it propagates further, that I'll be OK to drive it another 10-15K before it cracks again? Is this common for these cars? I'm pretty sure it's recent - since the AL SFB's. Is this a side effect of the stiffer SFB's? Should I consider SFC's & would they prevent this type of occurence?
TIA, as always-
TIA, as always-
