Cracked rear brake line
SHOed_up
Ann Arbor, Michigan
So, I was replacing the old collapsible rear brake hoses, and in fiddling with the passenger side hose (Ok, so I was using a chisel and hammer to separate the collar from the bracket, yay rust) I tweaked the steel hard line and it cracked probably 8"-12" from the end. I can't see the crack, but the dripping brake fluid from the middle of an otherwise dry tube seems a good indication.
What size of line/ends/tools am I going to need to replace this?
poffffd
