GEN 3 SHO FAN
I don't know what to think about these symptoms...
I just finish to replace all the rear coils because I have misfires at low and high rpms. I realize finnaly that it's a broken spark plug... Did the rear coils change anyway and replace the intake. I took the car some times since to go to work (25% city and 75% highway). Starting : ok, RPM : ok (no more misfires), heat : ok (25% gauge), shifts 1-2-3-4 : ok. Problem resolved, great.
But yesterday I decided to take the car and give a saturday night concert with my yamaha music instrument. After around 30 min. of city driving only, the car begun to have hazardous shifts. The RPM go up past the normal shift point and then it shifts with a **** or just not. It never does this when going to work. this trouble was there before I remove the surge tank and I tought I was caused by a bad coil. The trans fluid is clear red but not sure is the good one. I also notice that this seems heat related trouble (hot day or city driving). Downshifts are ok. Not sure it is related but I noticed the idle RPM was little irregular going between 600 and 700 (motor relearning to work with 8 cylinders ?)
I rode a lot here and on V8SHO site. I think about the things causing this (many). I didn't rode the codes recently, I will do this this week-end. Great thanks to you guys here I know some had probably face this kind of problem and will help me with it. I'm a little lost by now. Here it's the possible causes (from what I rode) :
1) The rear wiring harness which was toasting on the rear valve cover. I was forced to scratch it out from the cover. I checked the wiring and some isolation still there. I put isolation all along and modified the two metal brackets holding it to keep it away from the cover and not sticked on it (very good idea Ford !). Maybe it's damaged after all and I have shortcuts in it ?
2) The TPS (throttle position sensor) is not working correctly. I rode some posts on that. It's play on shifting. I don't remember the symptoms of a bad TPS... This part take time to gets hot it's why I'm thinking about it.
3) A faulty camshaft position sensor or a faulty crankshaft position sensor. These parts give the RPM to PCM. With time, they seems to accumulate carbon on the part inside the motor giving bad readings or simply no signal (with no start).
4) The possible bigger problem, a faulty transmission. From what I rode, it's may be the trans have faulty seals that when trans heat build up make the trans working not correctly during mostly in 1-2 shifts (something called ''flare hot''). When I bought the car, the guy selling it was a transmission guy saying he have too much cars and said to me that all was good on the car... The trans fluid seems to be almost new... (Bad fluid or bad guy ?) However, I took the car many times in hot summer days last year and I didn't notice that trouble. (Note : try first the Lucas Transmission Fix just in case if it's worn seals or dirty valves)
5) Also in last summer, we changed the gas tank (leaks). Maybe something went wrong with the fuel pump during replacement ? I rode in troubleshooting section that a guy had acceleretion problems and it was the fuel pump relay. I put the link for reference. From what I remember, I noticed the trouble after that (later in last summer). But I'm not sure how it can be a heat related trouble.
http://www.shoforum.com/index.php?threads/96-sho-bogs-down-on-acceleration.129479/
6) Something on the intake was not replaced correctly when I rebolt the intake last summer. Less possible but possible too, no ?
I don't want to scrap this car even if I hadn't paid a lot for and because I worked a lot on it. Thanks again guys,
