Coolant Temp sensor housing
ProjectSHO
reviving legend
Texas
Hey guys, I am a new member who discovered the forum surfing the web looking for answers. I have inherited my uncle's 95 SHO ATX. The bad news is both front and rear windshields were busted out, interior in shambles, and motor in pieces. I have almost got everything done but I hit a stopping point when feeling up the radiator with coolant. The coolant started trickling out of the right side of the motor behind the intake. after about an hour I had it back apart and the problem is the housing that the coolant temp sensor threads into had a major crack in it. Does anyone know what that housing is called or where I can get a replacement one? (sorry for the long back story):nut:
K-Dawg
Treasure Coast, FL
You'll also need Fel-Pro part # ES70426. I'd replace the o-rings on the crossover tube, as many hoses as you can while you're in there, and of course the gasket behind the housing.
Irish Pride
Irish Inside
MusicCityUSA
Hey Kelvin, do you know if there is a difference between ATX and MTX? There is an MTX one listed on ebay. #321128465596 Maybe the only difference is the thermostat housing and that could be swapped from the car.
not sure if exactly the same part #s but I know they are interchangeable.
