Coolant in the oil? 2011 Non-PP
jvan45
Dallas/Fort Worth Texas
2011 non-PP SHO w/ 160,000 miles. Last week I had my electric power steering rack and CV shafts replaced by a local shop. When I got the car back, it started dropping in idle from 700-800 RPM's down to about 400-500 RPM's at times but didn't notice an issue while driving. After driving about 50 miles, I hammered put it to the floor out of a toll booth where it threw a P0016 and a P052B code for crankshaft and camshaft timing (First gues was stretched timing chain). On my way driving home, the car shut off and the oil light flashed on the dash display. Checked the oil in the dark which was okay, and drove it the 2 miles home.
After letting the car sit overnight, I checked the oil again and it was quite high and very milky (coolant in the oil possibly?), and the coolant was low as well.
Here are the questions I'm asking myself:
- First thought is a bad oil cooler, but why would camshaft and crankshaft timing codes pop up?
- Could the mechanic who replaced the EPS rack, accidentally removed or damaged a hose when he replaced the rack?
Airborne
Gotten those codes before with coolant in the oil. Oil not thick enough to operate the cam phasers.
I had luck draining the coolant, changing the oil a couple of times and replacing the water pump. Still going after 80k miles
as long as the oil is metal free, you should be able to repair and proceed on your merry way. check oil in the pan, intercooler, turbos, and filter before you give it an all clear.
