compatible knuckles
smak
toronto
what year/make fords have knuckles that will fit my passenger front side '94 sho?
have had a bad wheel bearing that has probably chewed up the hub a bit and to be safe i'd like to replace the whole bit.
SASHO91
Zoom Zoom
San Antonio,TX
94/95 are the same and the only ones you can run, unless you downgrade your brakes to the 10.1's which would just be :slap:
You should be fine with a new hub and bearing assembly as the wheel would have to be noticeably wobbling while driving down the road to touch the knuckle.
Racer X
SHO Pilot, Retired
Connecticut
1994 - 1995 Taurus SLO, SHO, and Mercury Sable are all compatible, provided they were equipped with ABS.
