codes a popping
Craig
Richmond, KY
Hello,
I have a 1989 SHO. It is 20 years old but is in pretty good shape inside and out. I recently put a new exhaust on including the y-pipe with cats back. The dynomax exhaust has a bigger diameter than stock. My car popped 3 codes right away - 81, 91, and 66 (MAF sensor according to Autozone). My MAF had 250K miles so I put on a 73mm tube and new electronic part. The car then popped a 19, 41, and 91, The 91 points to the air/fuel mixture. The 19 is a CID circuit failure and the 41 is 'No EGO sensor switching detected'. Can anyone give me any guidance?
Thanks,
Craig
Richmond, KY
bubba
ATX Connoisseur
Fort Wayne, Indiana
Yeah you need a tune, to run that 73mm maf, and sounds like your crank sencer is going out.
Hello,
Thanks,
Craig
Richmond, KY
Craig
Richmond, KY
Thanks for the reply.
Thanks for the reply. My crank and cam shaft sensors are fairly new. I did ask the person at C & L about needing anything else with the 73mm. He said that I should be able to put the 73mm tube in with my old electronics and everthing should work without doing anything else. The MAF code group popped when I installed the exhaust before installing the new MAF.
ct
