codes 327 and 543???
Rob94
Northbridge MA
Code 327=DPFE output circuit below minimum voltage.
Code 543=Fuel pump secondary circuit failure.
For Code 327, I'd check your EGR valve electrical connections, and possibly remove the EGR valve and clean out the nostrils.
Code 543 usually means the engine has stalled and can be ignored.
kurtis adum
Driver
michigan
it stalls all the time, hopefully because of the egr valve. It stutters to. would that be the problem???
