BlackonBlack89
I pulled the codes on the black car quickly. I only did the off (o) test as it covered and put away.I will do the running test tommorow to see if anything shows up. Posting to see wat u guys think and help me figure this out.
Anyways here the symptons.The car bucks when trying to cruise/mantiain your speed. WOT and decel are fine and no CEL. Only at part throttle does the CEL come and goes. (when it bucks)
66 Vane Air Flow (VAF) or Mass Air Flow (MAF) signal low - VAF MAF (it a lincoln 80mm) maybe it bad????
16- O) Electronic ignition - IDM circuit fault - Ignition Systems
What is this and wat would I check. The car ran PERFECT before this install.
also theres no alt spinning as It's not on b/c I hooked up the s/c oil line today. Tommorow I'm gonna but the belt (
) on so maybe it will help.
I wanna figure this out first so I can actually drive it and enjoy it!!!!!!!!!:frantic:
*it has an LPM and the battery was on and off all day. code 15 showed but it say if the battery was unplugged so I figured that was it. If not its the no KAM power (uughhh ooo)
TIA for any help.
) on so maybe it will help.I wanna figure this out first so I can actually drive it and enjoy it!!!!!!!!!:frantic:
TIA for any help.
