Code Help???
New to the SHO
PopGoesTheWeasel
portland
I got a 93' ATX and the check engine light is on so I decided to run the codes at the autoparts store and this is what I got.
211 Ignition pickup Circuit Failure
212 Loss of Ignition Diagonostic Monitor input to spark output Circuit
327 EGR valve Position or exhaust pressure transducer ciruit below voltage minimum
332 EGR flow insuffcient
336 Exhaust pressure high
343 Fuel Pump Circuit Faliure
I Know nothing about codes and I was wondering if anybody could help me out with what could be causing any of these codes to come up. Any help is appreciated
crystizel
