code 526
marv
chicago
I am getting a 526 code nps circuit closed ac on. Can I simply unplig ac unit to bypass?
hawkeye18
Sorta cares
Norfolk, VA
Well, the NPS is the Neutral Position Switch, so I'd focus on that first... I don't know how the AC being on would matter... the whole code doesn't make a whole lot of sense to me.
hawkeye18
Sorta cares
Norfolk, VA
yeah... that's what it looked like to me. It was right between two "duh, you screwed up the test" codes, so I figured that's what it should be but I couldn't tell for sure...
marv
chicago
exactly
That's the point, i didn't have it running.......
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Does your A/C work? If it is say low on refridgerant, and the switch was stuck on.. it wouldn't run anyway. Mines dry, wont run if I try. Just a thought.
marv
chicago
ac
Maybe it was a stored code but I thought I cleared codes. Anyway the ac unit is causing my car to surge an I was told to pull relay or bypass it.
marv
chicago
ac
oh and no it does not blow cold air. I do have records of the ac clutch being serviced a couple of times.
hawkeye18
Sorta cares
Norfolk, VA
well if you want to bypass it, just pull the little plug on top pof the accumulator/dryer. That's the easiest way...
bmytych
