HappyGoneMad
I am having PP/TOB problems so I am going to have my clutch replaced but I am not going to do the work myself as I am lacking time/experience. From what I understand it's a rather big and complicated job on the SHO. My dad can get discount service and parts through his old work so I'm taking it there. The mechanic my dad knows is pretty good and has worked on SHO's before, including clutch jobs, but I doubt he is an expert on the SHO. In addition to the basic clutch kit and TOB, I understand that I should have the flywheel resurfaced as well. I also found a list of other parts that should be replaced such as the dowell pins for the flywheel, clutch cover-to-flywheel bolts, the TOB quill, the plastic pins that holds the TOB in place, the 2 plastic bushings, the felt washer and maybe the pinch bolts and rear main seal. I'm not even sure of the precise function of those last two. Anyways, I'm assuming the clutch kit won't come with anything more than the clutch disc, pressure plate and alignment tool, and the TOB will probably be stock revision B or whatever it's referred to. I'm not looking to spend any more money than necessary so my question is this: Other than the basic clutch kit, TOB and flywheel resurface, are any of those other clutch/trans related parts absolutely necessary to replace or can I get by without them (assuming that they are o.k. as is)? My car has over 113,000 miles and is driven lightly most of the time. The car's previous (2nd)owner took pretty good care of it and says he didn't drive it all that much but I have no idea about the car's first owner. What is the likelyhood of those parts being worn/broken/in need of replacement? I don't want to have to have the trans pulled back off because one of those little things failed but I really don't want to buy unecessary parts. If I had unlimited cash funds I would replace every little nut and bolt on the SHO but its just not possible. I'm in college!
Any feedback would be greatly appreciated!
