Hey all, brand new here. I just acquired an '89 SHO from a friend, it has clutch problems that need fixing before i can get it on the road. The clutch doesn't slip at all, but it won't shift smoothly into any gears. In fact, to get it in gear at all, you have to really ram it in there, not good. Every clutch i've ever had was hydraulic, so i figured i'd replace the clutch cylinders. This one isn't hydraulic, no cylinders! ahh!
Could anyone share some insight as to what may prevent a cable-operated clutch from disengaging properly? I thought the cable may be stretched, but my friend tells me this problem occured rather suddenly. Is there a way to test it? Is there another potential problem spot i am overlooking?
Thanks for any help you can offer!
