Bruce M
SHOBAM
1990 SHO 3.0L MTX.
I have replaced many ATX’s in these SHO’s and other vehicles along with and a bunch of other stuff as well but I never pulled out a manual tranny from a SHO.
The release bearing let go in a 90 MTX. Having done a ton of work on standards over years ago I tackled this job. Last clutch that I did however was in a 1983 ranger so it’s been a while. Everything came apart as advertised, had to install new manifold studs, and did an oil pan gasket and a host of other things while I had the tranny out. Took my time putting everything back together, lining up the tranny shaft to the clutch like you’re are suppose to and I was very careful at every step of the way. Tranny lined up nice and went together without any binding jamming or use of force. Attached the clutch cable and now I have no clutch or spring action, I did prop up the pedal as instructed in the SHO factory manual, but I think I may have released the self adjuster, I have never fooled with on of those. So question 1) if self adjuster has been damaged how would you know and can it be fixed, and question 2 is with a new clutch how much travel is there on the release fork that the clutch cable attached to, from sitting with no pressure on the clutch pedal to a fully depressed clutch pedal how far does the release fork move with a new clutch. With a new clutch where would the release folk want or sit without any pressure on the pedal, you know; like would it be parallel with the fin that holds the clutch cable insulator/nylon bushing, slightly forward, slightly toward the fin.
I did not study the action of the clutch, the cable or release fork nor did look at the pedal and self adjusting mechanism at all before doing this and now I know now that I should have.
I basically have no pedal or clutch right now and I would like someone who has done a bunch of these to chime in with tangible information that might help me if you would
Thanks
Bruce M
Thanks
Bruce M
