If you have the smaller one.. which you should.. you can use the larger setups I believe, but you need the larger flywheel, and the larger corresponding pressure plate / clutch for it.
Yes, I have or ordered a 9.75 flywheel. and already have a 9.25 clutch. just curious if i should order the 9.25 or use the 9.75 so i can upgrade the clutch later.
