MOSHO92
Well, with everyone's help (the forum, my buddies(for lifting stuff), and Joshua Texiera(video)) i finally got it done and put together.
Some notes and problems:
- The driver's side outer tie rod end just sat there and spun when i tried to get the nut back on. I cleaned the bolt and nut with a wire brush and i used antisieze but even with an impact gun i couldnt get the nut past the locking hole. There was no way to hold the bolt so i just replaced the damn thing for like 17 bucks. Now i need a new alignment....
- The Fidanza and ASB's are cool. I get a totally diferent feel with the ASB's, and the engine revs much easier and quicker now with the Fidanza.
- Problem 1: When turning the wheel i get an awfull vibration. The entire car vibrates violently and makes a terrible sound. This happens when i am stopped, moving slow, and moving fast. It has to be something with the PS system because the vibration continues as long as there is pressure on the pump. Like if i hold the wheel to the right (not actually rotating the steering wheel, just making the pump try and turn the tires) the vibration is strongest.
- Problem 2: My car is smoking like mad. Smells like grease or ATF that i spilled, or possibly PS fluid. I havnt checked yet because ive been working since 9 this morning and i just finished (its 11:30pm).
- Problem 3: (possible problem) My new clutch is almost twice as easy to push. Most likely my old TOB was just making it harder than normal.
- Problem 4: (possible problem) New clutch only engages during the last half of the clutch pedal travel. I tried doing the self adjust thing and it clicked a couple of times but didnt really fix anything. I will try a few more times every day but could this just be the way my clutch is?
------time for bed. Thanks again for all of everyone's help, i couldnt have done it without you. .
beer pizza will have to wait for tommorow. Im exhasted.
