Clutch cable bushing
JATO
Norman, OK
I just ordered a new clutch cable for my '89 transmission and I was wondering if the cables came with a bushing that goes in the bracket on the trans or if that was something I'm going to have to order separately from SHO Source?
JATO
Norman, OK
I was afraid of that. I'll have to give my local you-pull-it a thorough look once it thaws out.
jelloslug
Digital
Greenville, SC
If you are going to a you pull it yard the bushing on the clutch peddle bracket is the same thing.
JATO
Norman, OK
Nice to know, won't have to go hunting for a car with an engine/trans in it still. Thanks.
JATO
Norman, OK
Does anyone know if something from another Ford product is a suitable substitute? Maybe Fox Mustangs, Probes, or manual Tempos?
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
The 20yr old junkyard bushing probably will not be in not much better shape.
Is there a reason you do not want to get it from SHO Source?
JATO
Norman, OK
My issue is $17 for shipping for two small pieces of plastic seems high.
LOUDSHO92
Sponsoring Vendor
I updated the shipping so it should be better.
Next time if you email us we can see what we can do to fix a problem. If we don't knowe can't fix it.
JATO
Norman, OK
That is definitely better, thank you. I will be placing an order here shortly.
JATO
Norman, OK
My SHO Source clutch cable bushings showed up today and I am glad I made the purchase. The plastic feels like it's much higher quality than OEM Ford and looks like they'll hold up for quite a while.
