philjw90SHO
Hey guys I need some help. I have a 1992 MTX with 108k and I think my clutch is almost gone.
I have rough gear shift, high clutch engagement, and clutch chatter while at idle. I was curious how hard it is to do the clutch myself. Assuming I got the clutch video and clutch kit from shonut. What would I expect to pay to do it myself compared to a garage. I live near Portland, Oregon just for reference. If anyone knows a garage around the northwest with good service and prices.
Also I have a strange noise coming from the accessory side of the engine. My question is in reference to the timing belt tensioner. When I installed my timing belt 200 miles ago, I manually pushed the tensioner against the belt and tightened the bolt because I tried to just let the spring do its job, but when I started the engine, the timing belt was slapping because it was so loose.
Would tighting the tensioner manually cause any problems.
I can't tell exactly where its coming from. It could be an idler pully but i don't know. The sound is like a constant squeaking. The water pump is new. The noise is just slight. You can barely hear it from inside the car without the radio or the climate control on.
Thanks
<small>[ January 09, 2003, 06:19 PM: Message edited by: philjw90SHO ]</small>
Thanks
