blacklabel
Alright, so when I turn at tighter angles at slow speeds there is what sounds like a clunk. Sometimes when I straighten out it clunks back too. It seems like it does it more if I am turning at odd angles(out of the underground parking garage) or back up in reverse with the wheel turned a decent amount.
I recently have done a lot of suspension stuff. I have done Quick struts, end links, and this past weekend I changed the control arm on the passenger side(where it sounds like it is coming from). It seems like since changing the control arm, it occurs easier/more frequently now. I have been told the tie rods are fine.
From searching the forums, it sounds like this could be subframe bushing problems. I do have a reinforced motor mount on the front also. I just thought I would get some more input before ordering some. Maybe there is something I am completely overlooking.
Thanks
Thanks
