Climate Control is Hyper
kjlookinup
PA
The blower motor on my 1995 Ford Taurus SHO always runs in high. This car has the electronic climate control system. I can control the location of the air (defrost, vent, floor, etc) and I can control the temperature, but I can not change the fan speed. It always blows high, sometimes with the ECC off (when you turn the vehicle off the blower shuts off also). I replaced the dash control unit with no improvement (needed to be done anyhow) Where is the speed control for the fan motor located? What should I look for on Ebay? Thanks for any help...
whiteman_01
Well-Known Member
Hastings, MN
You need to replace the Blower Control Module. It is located behind and slightly under the glove box. IIRC it has about a 3/4 hose or 2 going to it. Its been a while since i replaced mine. Im sure a quick search would net you pics of the BCM.
