Climate control fan stuck on!!
mulejacker
Westchester/NY
Hey everyone. As you can see from the title, my fan is stuck on. It's the electronic climate control and is annoying as ****! I read about the same thing happening to someone else a WHILE back. I need to know exactly what went bad, so that I know what to fix (if possible). Thanks! burn_out
91MochaSHO
Ashford, CT
Its the blower control module. It is located in the passenger side area of the dash. It is located underneath the glovebox on the blower motor housing. It has two hex screws that hold it in place and it inserts into the housing. There might be a white label on it with black text. When you pull it out it has a mini radiator looking sensor pickup. Pick one up in a junk yard, thats what I did and mines been fine for 2 years.
