Marccus
After starting the car, I hear clicking noises behind the Climate Control Cluster on the instrument panel like something is trying to turn on (a relay?). Clicking can go on for 30 seconds.
Then after the clicking stops, I hear a whining noise that decreases in frequency and volume as it stops. Total on-time for whining noise is 5 seconds.
When this is all over, sometimes the heat will come on at the defroster location at the windshield.
Just recently, the climate control buttons won't work and the temperatures (outside or setting) won't illuminate in that little window.
Haven't used the AC in years because don't have money to fix it right now (don't really miss it).
I just blow hot air from A/C setting but it may just be refrigerant is gone or many other leaks /problems. I've never had any trouble with the car mechanically or with the engine all during this time that can be traced to the A/C. Just "normal" SHO troubleshooting.
SHO is '89, 275,000 mi., stock.
It's just a pain when the heat comes on at random times.
Then it will stop at some random time later - 10 minutes, 1/2 hr ...
Can you advise?
Can you advise?
