Cleaning the rear view mirror
javon7065
Philadelphia, PA
Noticed this morning that after using Zero Odor Pro to try to attack a smoke smell in the car I got some overspray on the rear view mirror. Do I need to use something else than Windex?
hopefully there's no haze. i generally use sprayway to clean larger areas of glass. clean w water/soap first if that's not enough, try the windex. imho.
kryptto
South East, Florida
javon7065
Philadelphia, PA
@javon7065 Here is the process:
Use Mr Clean https://www.mrclean.com/en-us/shop-products/magic-erasers/magic-eraser-extra-durable
Magic eraser in clear distilled vinegar, lightly scrub the mirror - wait till try, use a clean microfiber cloth gently rub the marks off the mirror left by the vinegar. DONT DROWN THE MIRROR - it has electronics in it.
Use a 50/50 Rubbing alcohol and distilled WATER mix with a new Mr Clean sponge. Wipe dry with microfiber.
Done.
Thank you for this advice. Because it has electronics in it I was concerned. Other than that I would've just used Windex.
kryptto
South East, Florida
let others know if you follow this advice and if it comes out fine like i expect.
hosbaldosho
