Clay Needs help
zblackbeast
SHOtarded
Omaha, NE
Qhat would you like to know... Its not DD in its condition. Needs a new PS pump, new pass caliper bracket (great opportunity for the 94 95 brake upgrade), and i put the brakes on wrong so its rubbing the rim :)scared:). other than that i think its ok. it just needs alittle more TLC than i can give it.. plus the parents want it gone! :(
Residual test....gonna be really ***!!
NEp8ntballer
cyber ninja
fifth circle of ****
mileage, rust, etc. the typical crap you would list in a classified ad.
I'm not really looking for a DD at the moment since I have the Jeep, but I'd like to park the jeep in the future until winter or bad weather hits. I just have to find a way to make sure that my parents don't let my sister drive my jeep instead of her car so she doesn't go over the milage on her lease. but I've spent enough time under the hood to know what I'd need to play with for it not to crank. plus I don't need her putting stains on my seats if she hits one of the bumps that causes a little death wobble.
I've never taken that exam or even know what it is so it must be lame.
zblackbeast
SHOtarded
Omaha, NE
170000k on lower end 20k or so on heads. small rust over rear pass tire. old tires. brakes are newer interior clean for a 15 year old car etc.
zblackbeast
SHOtarded
Omaha, NE
I was looking at the sho and it was smoking from the crank pully... front main seal maby?
zblackbeast
SHOtarded
Omaha, NE
yea. the smoke is on my new sho...
tranny has 120k or less i believe. shifts amazingly The shifter box sits to far back so it wont go into second (easy fix, just havent done it) no gremlins. cel comes and goes, ill pull codes when i get a chance.
NEp8ntballer
cyber ninja
possibly an O2 sensor if it's intermittent. I'll definitely have to give it some thought while I impatiently wait for the gov't to get me my money...
NEp8ntballer
cyber ninja
If I knew I wouldn't be so impatient. I need to fill out my travel voucher anyway so I'll probably drop by the ROTC detachment on Monday to ask some questions, like when am I getting paid...
joefriday
Ex-SHO owner
Nebraska
Hey clay, as far as the oil leak and burning you noticed...I'm pretty sure it's the rear main, as I said to you over the phone. The reason you might have seen the smoke come up the front of the engine is because a drop of oil probably hit the rear exhaust as it dripped off the bottom of the pan, and at that point, the smoke will rise however it can. Be assured though, the rear main is not a fast leak at all. Like I told you prior, it will take about a quart in between oil changes, and to the best of my knowledge, it's not caused any clutch related malady yet. I'd say, watch your oil level, check it every 1,000 miles or so, and when it comes time for a new clutch, tackle the rear main at that time. That was my long term plan at least. Good luck. I'll see you Friday.
Joe
PS: about the ALSBs: I pulled the bolts with the ALSBs for that very reason: in case my old bolts were corroded. The bolts I took out with the ALSBs look brand new. In any case, I know the car has had all the recall work done to it in the past, including the subframe rear plate nut replacement campaign, special service campain #98S36 at about 45,000 on January 1999 (it's in the records, work was performed at Markel Ford). The only recall currently withstanding is the cruise control recall...I never got to getting that done b/c the Ford dealership I go to never had the kits in stock when I would inquire about it), so I think the ALSBs should be good to go as for installing them.
