Classy or Trashy?
bpd1151
Lurking Around
SHOcago 'Burbs
He was Cleetus, before Cleetus was Cleetus.
**** YEAH BROTHER!
Damn right I was.
I had the Ron Burgundy **** stash too, well before RB ever became in existence!
Sex Panther was da bomb diggity.
Damn right I was.
Works 60% of the time, EVERY TIME!
GotGrip?
Conversation Ruiner
Minnesota
Hey man if you get a chance post a pic of where you mounted the the lights
I can get pictures of where they used to be, something hit the relay box somehow where I had it mounted and **** the whole kit. I'll probably get another one since they are super cheap and really easy to hook up, was just a bit bummed and my daughter was crushed D:
COMpulse
Detroit Area
All of mine are rigid LED strips with zip-tie mounting.
On the sides of the car, I tucked my rigid LED kit under the plastic trim, and the light shines at a good angle down and toward the outside of the vehicle. I had originally mounted the LEDs to the bottom of the plastic trim, but they were visible below the car. Now they are out of sight.
SHO2 LEDs 0
In the front, I just drilled some small holes in the splash shield, and supported the LED strip at the ends and the middle with zip ties. If you're planning to use adhesive LEDs, a couple zip ties might still be worth adding.
I didn't do the back of the car. I put my 4th LED strip in the upper grille (and added a splitter and 5th LED strip for the lower grille).
It's been 4 months and I've had no issues, except for the time I forgot they were on and drove it somewhere. People kept pulling up next to me on the freeway and I had no clue why.
I want to do the wheel wells.
GotGrip?
Conversation Ruiner
Minnesota
SHO2 LEDs 0
That is pretty much how I had the sides done, I put the rear one up under the bumper by the rearbody/trunk area, and they front one I put on the lower splash shield just behind the air dam on the front bumper area.
Chuck Johnson
Columbus, OH
Thanks fellas that helps alot, especially since i plan on getting the OPT7 kit. Now I know it will fit where i was thinking it would.
gwrabbit
Wisconsin
On a daily car? Nah, I'm good. State troopers here are ***** and will get you for anything they can (somehow I've gotten all warnings though).
On a show car or a car meet? **** yeah, those little lights of mine are gonna shine.
Joel Groff
Ohio
I had LED's installed on mine.
But it was primarily for the SHOw aspect(s) as that is a category that is checked off and points scored for it's implementation. Particularly at larger, national based events.
The local car club I roll with, each of the owners has them as well. In varying colors, placement, etc.
I kind of like 'em. But I can understand why others wouldn't want them.
Meh. Each their own, as always.85a2a94b79a014c4ca33a8062ef38b118b22a3045d672a19e389faf282f42315988711e401ac60726ab6ce98a734b276Ae991fb02beedf3baadd1164ae35c0e0426e3528fafd7214bcf818716a36113d
Dude your car is ******* sick....I love everything about it.
