clacking from start with heavy acceleration noise
nannho
2010 SHO
The Chi...
OK need some help as I checked the TSBs and couldn't necessarily found anything. Scenario is below:
At a light stopped and there is a civil next to me. Light turns green and this guy guns it. He either has the biggest ******* hole in his muffler of no muffler at all. I was on the phone and gunned it to get past this guy, and maybe around 30-50 mph I hear this loud, machine gun, clacking. Very short like 2 or 3 seconds, like 4 to 8 clacks and defiantly from the SHO. It sounded like I put a golf ball in a jar and rapidly shook it back and forth against the glass, or something to that effect.
It was about 40 degrees and clear. Directly prior I was sitting in a lot idling for 10 min or so.
What could this be? Has happened one other time that I can recall.
Knock sensor or condensation on the intercooler? Was slow to shift through as well, as I was getting on it.
Tried to repeat issue and could not. Any ideas?
Was it like marbles in a jar? That could be one or both converters, which would lead me to suspect leaky injectors (a more common issue than people think). Did you have a loss of power during acceleration at that time? Any fuel smell at all?
Would help to have your SHO's info in the signature area of the post :)
nannho
2010 SHO
The Chi...
Ya there is always a delay when getting heavy on the gas. And if it was similar to a big marble in a glass jar, sure...very similar sound. I couldn't recall if I smelled any fuel.
Car is a CPO car too.
Car is a 2010. I'll put that detail in. Thanks!
wuzzzer
MN Moderator
St Cloud, Minnesota
I believe I have had that same sound. The shift from 1st to 2nd. I attributed it to the rear differential and traction control limiting power to the rear. it was a loud tick-tick=tick that was coming from the rear of the car.
nannho
2010 SHO
The Chi...
They range was probably first to second...definitely. It happened quick so was hard to pinpoint.
nannho
2010 SHO
The Chi...
happened again and this time the TC was off. it was from a stop to acceleration, in first gear...maybe shifting to second...maybe. And after thinking about it, another variable I noticed is this has happened when the car was shut off off, and I go somewhere. For example, both times, I got into the car and at low speeds (less than 20) and for short time of driving (5 minor so) came to a red light. I stopped, sit, and then when, green accelerate with a little pressure and there is it.
nannho
2010 SHO
The Chi...
Any fixes or ideas? anyone else?
bmytych
