Chirping noice from the right rear.....
supersport
Pennsylvania
i replaces the rear brakes (calipers and rotors)about 2k becuase the right rear brake was not releasing from the rotor...when i got to the hoses to check if they were ok i soon found out that it was only the hose that need to be replace but...now 2k miles after when i let the car sit all night and then drive around its sound like the brake is sticking to the rotor..but when i check the rotor is cold...any suggestions...i think it might be a bearing or the whole axile is bad because i drove around a while before notice the caliper was stuck
Storm-Chaser
Shit Louis
Is the noise tied directly to vehicle speed? If so,...
... remove the wheel and caliper, leaving the caliper bracket still attached and see if the rotor is warped and rubbing the caliper bracket.
poffffd
