I just got a '99 sho with 28,500 miles and transferred my '97 mods over. First, I sent the SuperChip to be burned based on the new ECC code. Cleaned the computer connectors thoroughly, installed it and started the car (started fine but I should have test driven it for a day or two). Immediately I took out the stock air filter to replace it with the ShoShop Cold air box. Disconnected all cables for easier access to bolts. When I finished I attempted to place a small sensor(mass air sensor??) in the cut out made for it (push and turn to lock). It was not simple so I figured the sensor should be disconnected. After disconnecting from the tip the car made a gasp noise(or release of air noise) with the battery disconnected. Disconnecting the MAS at the tip did not do the trick so I connected it again and was able push it in enough to turn it an lock it. I turned the ignition and the car sounded like it pulled in air and stopped turning over. I turned it over agian and it started fine. Drove it down the street and felt the benefits of both products but it immediately started to stall under 30 mph and at stop lights. It was 1:30 a.m. and I felt like crying. The service engine soon light flickers and something on the drivers side of the engine where the air filter is makes a clicking noise. Have to turn the car totally off and start it again. headbang
Any ideas? Start by removing chip?
<small>[ July 29, 2003, 08:46 AM: Message edited by: v8mod'99 ]</small>
