Check Engine Light on because of sensor(s)?
Blue-By-U
CT
Ok, my CEI light is on and I don't know why. My 89 has 102,000 miles on her and I believe the O2's need replacing. Would replacing them solve the problem? They might be stock :( yes I know they should have been replaced at 80,000...they will be done shortly I just want that damn light off. I recently replaced was the TPS. Plugs and wires are also due.
Any insight will be appreciated.
Thanks!
~Alex
Mike Kopstain
Arlington Heights, IL
Alex, anything we tell you without first knowing those codes would be a guess. Get those codes run and chances are we'll be able to tell you exactlywhat needsto be done to remedy the problem.
Porod
Green Bay, WI 54301
Autozone will run the codes for you for FREE. Check it out, and then post what they tell you, and someone here will give you the help you need. :D
Blue-By-U
CT
Thanks guys I will def have Autozone run them then let you know
poffffd
