temptar
Hey all- 95 SHO here, 103,000k on it. Check engine light has been coming on for about 6 weeks now. Normally goes off after a mile or two, but the last two times it has come on the entire car starts jerking really strong. The jerking stops when I let up off the pedal and does not die. However when I accellerate the jerking comes back. It does eventually work itself out normally after about a mile or two. I have seen mention of this problem here before but have not seen a fix. Any answers would be great.
I'm sure this isn't your problem but it does sound like it could be a bad DIS; that or a failing fuel pump. Run the codes and see what you get, I wouldn't be surprised to see either a fuel pump or DIS code come up. Hope this helps.
