Anyone have ideas for a place to buy all things needed for the 60k on my 3.2L? I can get napa parts for cost but some are still quite expensive like the crank sensor and water pump. Any help is much appreciated. Thanks.
You should also do the cam seals while you're in there. You'll be mad at yourself later if you skip them and they begin to leak.
gmail, $1000 on 60k parts is absurd. Total parts for a complete upper and front 60k shouldn't be more than $600.
****, even with you using as many Motorcraft parts as you can find, you still wouldn't approach $1000.
head gaskets new bolts etc like i said i rebuilt the engine olny thing inside i didnt replace was pistons and rings
Was just lookin to replace crank sensor, timing belt, waterpump and crank seal. car runs good, has no leaks, just thought of preventive maintenance.
