Changing Inner Tie Rods
Hank F.
Portland, Oregon
Any suggestions to make this easier? It looks intimidating as ****. What special tools will I need? Should I change PS hoses while I'm back there, too? HELP! 93 ATX. Thanks
Reddy2
Indiana
Go to www.shotimes.com for an article about this replacement. The procedure was found under FAQ . It is detailed and just what you need. or I might say just what I needed when I did my inner and outer tierods on my 93 ATX -Terry
TYSHO
Earth
Just remember to remove the pins before you remove the inner tie rod, or you'll be replacing the rack. :shappens: :)
TYSHO
Earth
sdpatt said:
Just for the record, the "inner tie rods" are the "tie rods."
And most still refer to inner and outter, including auto stores, to prevent confusion with those who don't know the difference between the tie rod and tie rod end.
