187 SHO
i was wondering what parts i need to change the lug pattern to a mustang pattern.i have extra suspension parts laying around.i wanted know if its possible to ditch the 5x108 pattern
Is it really that hard to get a set of hub blanks turned and drilled these days? I mean I'd imagine it's mostly lathe work, a little bit of CNC for the splines and some drilling for the bolts.
They would cost hundreds of dollars just to get the hubs made and ask anyone here, not many people will spend hundreds on these cars.
'93 Taurus Wheel Bearings; Bore=1.6535", Outer Diameter=2.9921", Width=1.5354"
'93 Villager Wheel Bearings; Bore=1.8504", Outer Diameter=3.189", Width=2.0866"
Look to be too big.
Do you if the rotor was to far out from the hub or to close? it it is to close thats a fairly easy fix with longer bolts and a spacer to move bracket, but it was to far away from the hub thats a bit iffy.it made the rotor and/or caliper mounting next to impossible.
