change the bolt pattern
187 SHO
west babylon,ny
i was wondering what parts i need to change the lug pattern to a mustang pattern.i have extra suspension parts laying around.i wanted know if its possible to ditch the 5x108 pattern
silverknight
i race taurus?
st clair shores, michigan
Redrilling the hubs to a different pattern and installing new wheel studs. Preferably with a hubcentric wheel. I will be undertaking in the sping on my drill press so I can use stock fusion sport wheels.
hawkeye18
Sorta cares
Norfolk, VA
This is a topic that comes up with some regularity - I don't know of many people that are happy with this stupid 5x108 bolt size. To my knowledge, though, nobody's come up with a way of changing it that doesn't involve drilling out the stock hubs.
Maybe some day...
Spring Hill, FL
Is it really that hard to get a set of hub blanks turned and drilled these days? I mean I'd imagine it's mostly lathe work, a little bit of CNC for the splines and some drilling for the bolts.
jelloslug
Digital
Greenville, SC
They would cost hundreds of dollars just to get the hubs made and ask anyone here, not many people will spend hundreds on these cars.
Phoenix
SHOHOLIC
QC , Canada
I got the front hubs done for like 40$ in a machine shop. 4X114 was the target , they had to plug a hole though (weld).
Maybe its possible for the rear if you either tap the holes and screw in studs (with 100% threads) , or tap and use male wheel nuts (like the festiva / saabs etc.)
I donno though I havnt done the rear.
93markVIII
MO
the fronts are easy. redrill is simple, or possibly press in a 04 cobra rear wheel hub. rear mustang and front taurus have the same wheel bearing.
its the rears i haven't seen anything yet.
i read someone used a set of sleeves and mounted hubs from a 5x114.3 car on the rear. but i never found any useful info on the sleeves, or the car itself.
i suppose with some caliper work, you could make some sleeves to mount a front mustang hub on the rear of the taurus.
going from this:
getimage.php
to this:
getimage.php
but i have yet to take apart the rear of a taurus so i do not know firsthand what's back there. and whether or not this would change the offset and mess up your rotor alignment or not.
intimdatr
Got Cams?
Jefferson City, Missouri
If i ever get the time and money im gonna send my fronts to Saturn5 and have them drilled and laying around just in case. and i will start thinking on the rear.
Still jealous of how easy swapping yours was :mad:
Heres what we have to work with in the rear.
this one looks promising...
Dxnj 512105 bac
Rockauto-Timken
187 SHO
west babylon,ny
thanks for the info.i need more parts to mess around trying to make the swap work.its just seemed like there could have been something out there you swap it out with.somewhat cheap.like stuff i could pick up from a salvage yard.
ohioshodude
SHO'ld fogy
delaware, ohio
fronts as its been said are they easy part. just re-drill the hubs. the rear is where the issue is. I've been working on using sn95 mustang front hubs on the rear but the tone ring is different and its smaller then stock, the bearing center is larger and would require a sleeve, and the actual hub is smaller at the width. I'm looking into probe hubs now as they are closer in size but still will require a sleeve.
Spring Hill, FL
GROUP BUY!
Seriously though, I wonder if a group buy of blank hubs would be feasible, let people get whatever pattern they want.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
anybody have a Nissan Quest/Mercury Villager from 93-98 laying around to look at for rear hubs? Pattern is 5 x 114mm. NAPA only shows the bearing, I have no idea what the rear hub looks like.
We may want to check the front hub spline count, it looks similar to a Taurus.
Perry
Spring Hill, FL
'93 Taurus Wheel Bearings; Bore=1.6535", Outer Diameter=2.9921", Width=1.5354"
'93 Villager Wheel Bearings; Bore=1.8504", Outer Diameter=3.189", Width=2.0866"
Look to be too big.
iirc, the last time this came up the closest hub for the rear is the Windstar hub, but the offset is different so it made the rotor and/or caliper mounting next to impossible.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
Look to be too big.
the inner diameter of the rear bearings is 31.75mm/1.25"
intimdatr
Got Cams?
Do you if the rotor was to far out from the hub or to close? it it is to close thats a fairly easy fix with longer bolts and a spacer to move bracket, but it was to far away from the hub thats a bit iffy.
Anonymous
Philadelphia,PA
I wanna put a set of jaguar S type R wheels on my 95 ATX the wheels are 18x8" front and 18x9.5 rear with the same 5x108mm bolt pattern ..I wanna know if I can make it happen
shobroooo
