89shofun
Guest
ok i have 89 mtx heres my codes
koeo
11 sys ok
54 iat signal high
16 (O) Electronic ignition - IDM circuit fault - Ignition Systems
66 Vane Air Flow (VAF) or Mass Air Flow (MAF) signal low - VAF MAF
Transmission Oil Temperature (TOT) signal low (possibly grounded) - >Transmission
79 A/C is on or pin 10 is shorted to power
i had 21 the first go through before it repeated but not the repeat
21 Engine Coolant Temperature (ECT) sensor out of range - ECT
koer i got 13 and 21
13 Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too high)
how do i fix these i need hlp plz thank you
koeo
11 sys ok
54 iat signal high
