Blank-Disk
You'd think I'd be able to see where tons of Antifreeze is comming from, but no such luck. I put the 93 ATX on a lift, and still couldn't see it. All I can see is antifreeze comming off of a heat shield located right behind the passenger headlight, all the way on the bottom of the engine compartment, I think there's an exhaust pipe under the shield. What's is there above that that could be leaking Antifreeze?
