Can the Accelerator Pedal be adjusted?
rigol2000
Need a 60k
Southern Louisiana
I'm giving my new SHO the once over and noticed that the accelerator pedal in my new 95 is lower to the floor than my 94. Can the accelerator pedal be adjusted forward so that it is closer to the height of the brake pedal? Right now there are several inches difference.
Thanks!
1993MTXSHO
Its a Taurus...
Jersey
im not sure if its adjustable but if its a lot lower check to see if the bracket that holds it is bent:thumb:
revhardSHO
Seattle, WA
No I do not believe that the pedal itself can be adjusted. The pivot point is static.
You may have a streched throttle cable. If that is the case, bringing it back into spec will raise your gas pedal up to the proper level.
poffffd
