I have been chasing an oil leak, which I though came from the front crankshaft seal, (which I had replaced several months ago), only to find that it was clean.
After cleaning and searching around the engine for a while I found the culprit: the front camshaft seal.
After reading the manual, it says that I have to remove the cams, and use several specialized tools.
Are there any short cuts to this proceedure?
Can the seals be replaced without removing the cams?
The oil leak was traveling down the front of the engine, under the plastic cowls and running over the lip of the oil pan to the transmission. I though that both front and rear crank seals were leaking. I was dreading having to remove the tranny again.
I guess I should have replaced them when I had the engine out.
