Cam Install pointers
jayro
Auburn, In
I am going to be installing a set of TriFlows in the next few weeks in my "94. Is there anything special I should watch out for? Any pointers from those who have done this before? Thanks
Jeremy
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Make sure you have a shim kit. Be careful with cam cap bolts. Its a rare thread and you cant exactly just re-thread. Try and ind some new dust shield gaskets for around the cams. Yours are probably brittle.
You can do a top 60k while you are there.
jayro
Auburn, In
Thanks for the pointers. I have a shim kit coming with the cams. I read that it was easy to strip out the cap bolts. I Iwas planning on using a torque wrench set to the lowest torque spec to make sure that I dont strip them out.....is this what is recomended? I also have a new timing belt, cam seals and valve cover gaskets. I guess while I'm there I could do plugs as well. What wre the dust shield gaskets?
Jeremy
LOUDSHO92
Sponsoring Vendor
The torque rating is really low. You would need a small torque wrench. Maybe just use a small wrench and don't over exert.
The dust shields go on the inside of the timing belt cover and go around the cams.
