Cadence 6x9 mid-bass
sandrew
Omaha, NE
True but there are people afraid to lose trunk space. Combine that 6x9 with a small amp that can push 150w RMS @ 4ohm screwed to a seatback and you keep your space and the ability to fold the seats down if needed.
/shrug
Just a possible option. The stock JBL sub/amp is pretty weak. :p
NebraskaSHO
Harumph!
Omaha
I like my 12" single sub box I made and amps mounted to the side of it. Sounds great.
sandrew
Omaha, NE
I like my separate sub in a sealed box as well. This was just offered as an alternative.
SuperHO
Mental Patient
St. Joe, MI
the thing is, that's not designed to be a dedicated subwoofer. it's meant to bridge the gap between subs and mids. if you don't wanna sacrifice trunk space, do a search on infinite baffle setups.
sandrew
Omaha, NE
Again, it was just put out there as an alternative to the JBL sub in the 96 (or any other Gen 3, they all have the cutout). I realize that this isn't considered a "real" subwoofer.
It is, however, the same size as the JBL, can get as low at 40hz as the cheap JBL, is much beefier and can handle more power. If crossed over at the same frequency it would be a good substitute for what's already there in a 96 or for a 97-99 owner that doesn't want to mess with a sub box and understands the limitations. If you don't want to be heard coming down the street but still want a little extra depth to your music it would be just fine. Consider it a stock JBL piece on steroids.
This isn't a thread for complaining "that's not a real sub" or for saying "my xx-inch in a BOX is soooo much better". Again, I was just pointing out an interesting find as an alternative, especially since pretty much nobody makes these anymore.
For myself I went with a 10" sub in a small sealed enclosure. Not too much boom, not too little, but just right in conjunction with the rest of the system which has also been upgraded.
If, however, the car in question was just a 2nd car, or for a significant other, child, parent, etc., you can bet I'd toss one of these in there, upgrade the front speakers and call it a day.
That's all this was intended for. If y'all want to start another thread about subwoofers and type of boxes, stereo upgrades, show off your systems, whatever, feel free. I was just trying to give an alternative to the stock JBL "sub".
NebraskaSHO
Harumph!
Omaha
Also, don't forget this speaker isn't 13 years old so if you would want to keep the JBL system working and have a blown sub, then there you go!
