Buying the turbo
MYSHO1
PiCkLe DaNcE!
Wakefield Ma, e.p RI
I have the money ready and one all lined up, like i said in the past post im not going for crazy boost right now. Just wanna make sure i dont over spin the turbo. Would one with these specs work?
GARRETT INTERNALS T3/T4 T04"E"
. 50 A/R COMPRESSOR
.63 A/R TURBINE
.57 TRIM
5 BOLT EXHAUST ******
BRAND NEW
FOR A GREAT POWER BOOST
WET FLOATING BEARINGS
COMPRESSOR HOUSING A/R RATIO .63
SASHO91
Zoom Zoom
San Antonio,TX
thats almost exactly what i have...
its alittle bigger than mine...
sounds good to me! :thumb:
92sho16
b00sted
Liverpool, NY
I would go with a 60-1 turbo or 62-1 right off that bat that way when you do upgrade you wont have to go through selling one. I would believe these two turbos wouldnt be overkill at lower psi either so you dont have to worry about blowing the engine up. On a side note does toolman still have his old turbo? maybe you could buy his old one?
munkee
Too busy...
Missoula, MT
That would probably be alright. Should spool pretty quick and overspinning shouldn't be a problem if you don't try to run high boost. I like the turbonetics 60- series turbos myself but there are a few others that can produce the desired results. Just an FYI, the 62-1 is physically a much larger turbo than the 60-1 and you won't want to use the 62-1 if your planning a low boost setup.
wunfstmax
Colorado Springs
That is a turbo you should put on a h22 honda prelude. I have a maxima with a 3.0 which is similar displacement to your motor. I have a t04b with a .63 a/r on the compressor, and a .81 on the turbine and its in a 55 trim i believe. Your top end will suffer greatly, but youll have great spool. I hope it isnt a turbo from xspower or ssautochrome though, seeing that you listed it has "Garrett internals".
If you look here you could find some good info in the stickys section.
http://forums.maxima.org/forumdisplay.php?f=53
MYSHO1
PiCkLe DaNcE!
That is the exact company/brand, Why is this. Can some one PLEASE help i bidding ends tommrow!
MYSHO1
PiCkLe DaNcE!
Wow i just did a search and in 5 minutes i found about 30 threads on other forums about how they blew the turbo up in the matter of a day from these guys....
So any one know of any good used, or fair priced new ones....
MYSHO1
PiCkLe DaNcE!
Damn.... Back to square one.... I knew there had to be somthing wrong 375 for a BOV wast gate and a turbo..
wunfstmax
Colorado Springs
haha, well its good thing that you didnt buy it though. Those are all things that you want from a reputable company, they control, regulate, and create boost, definately not something you want to skimp on. good luck with your project though.
MYSHO1
PiCkLe DaNcE!
Garrett T04B Turbocharger
Up for auction is a nice used Garrett T04B oil-cooled turbocharger. The a/r on the exhaust side is 1.15 and on the compressor side is .60. The Inlet on the compressor side is 3 inch and the outlet is 2 inch. The exhaust inlet is tang divided for fast spooling and has the standard T4 ****** as seen on most aftermarket turbo manifolds. The compressor wheel is a T trim and the exhaust wheel is a P-trim. The shaft spins freely and has no play. As you can see in the pics the turbo is in very nice condition. This turbo will produce over 400hp. Get it here cheap!
*Read*
Is that to small?
92turboshoprobe
Coos Bay, OR
www.agpturbo.com = good decent priced turbos with good people to deal with. You can get a T3/T04E but make sure you get an .82+ A/R exhaust housing. THe AGP61 is a great turbo, will blow a 60-1 away in just about every way.
If it looks too good to be true, it is when it comes to turbos.
For most good turbos plan on spending at least $600-$700
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
I got a brand new T66 turbonetics. Its probably much more than you want to spend though...
1slickRED89
Guest
Toledo Ohio
if you want a nice turbo, and not a cheap one. call turbonetics directly and order what you want, you'll pay $800 for a conventional unit, but it will have good features. things to look for are 360 degree thrust bearings and dynamic balancing to name a few.
poffffd
