Broken Shifter Cable
JC
FORT RUCKER, AL
Does $540 (including maintanence) sound right to replace the broken shifter cable fromt he **** all the way to the tranni? Its at a Ford Dealership right now... and thats what they are going to charge me if I agree to it. Thanks.
Ishodu
I wouldn't do that. There should be tonnes of used shifter cables around. And you could also upgrade to a rod shifter for around 150 dollars for a used one.
JC
FORT RUCKER, AL
Well they said the cable was roughly $200 or so, the rest is labor. What advantages does the rod shifter have over the cable?
Ishodu
No more broken cables, shorter shifter, better feel to the shifts. To name a few. Will only take about 1 hour or so to install.
Ishodu
Defiantly you could do it at home with tools and some know how. Try a search on this it should come up with some better answers than i can give you.
SHO_Driver
Montreal, QC
It also depends where the cable broke. They have a tendency to pop off at the transmission linkage. Some of us just wire tie it back into place. I also wrapped some hard wire around it, shifting fine for the last 2 years.
tripleblack90
SRT Owner
Waterford,Wisconsin
thats the route i went, my linkage popped off last week, i wrapped some 19 gauge wire around it and its been fine, but if the linkage broke, definitely look for a rod shifter
