Brakes Not Funtioning Properly
SHOwener1986
I just finished my install of springs and struts and i noticed that when I stepped on the brakes the pedal went further down than usual. Upon further investigation i noticed that when I pressed harder the car twists much like only the front right and back left brakes are functioning. I dont think its the master cylinder because the pedal doesnt slowly leak down to the floor. I NEED HELP
Thanks
TimboSHO
Intermediate
Wyoming, MI
When you did the struts/springs, did you disconnect the line from the caliper? That would put air in the line. If so, I would bleed the brakes. Also, look at your brake lines. Maybe the moving them around could have weakened them and they are leaking. Check the level of fluid in your master cylinder as well, it could be low.
