Bruce
Ok Guys, I'm stumped. I'm wondering if you can give me some ideas on what my problem might be?
I FINALLY finished my '96 front disc brake upgrade on my '89 and I have a problem with it. Under hard braking (and only hard braking) there is a shuddering going on in the left front. When I installed the new knuckles I replaced the bearings in them, I also put in new lower ball joints including the LCA's, I have new rotors (run-out is .0025") new PF pads, I rebuilt the calipers, bled the system, serviced the slider pins and have some anti sieze where the ends of the pads fit into the caliper brackets. I brought my friend over to look at it and drive it and he's stumped also. It only does it under hard braking. I was thinking of just driving it for a while and see if anything changes once the pads bed in better. I thought I'd bounce this off of you guys and see what you think? We both double checked everything and it's all tight! Wheels are torqued to 95 ft. lbs.
It's making my brain hurt thinking about this! headbang
Mucho Thanks,
Mucho Thanks,
