What do you mean by brake systems? Do you just want ideas on replacement pads? Do you want upgrade options including larger rotors? Do you want to go all the way and change the calipers to a multi-piston design?
Are you looking for just upgraded pads, or a complete system?? www.tceperformanceproducts.com is the best and most expensive. www.baer.com is the very good upgrade and not as expensive. The other thought is the 96' upgrade, which would be the cheapest.
I have both systems Baer (13'' PBR Track II,2 piston,zinc washed and cross-drilled) and TCE Wilwood (13'' Billet Superlite 6 piston calipers,zinc plated and gas grooved) on my two sho's. Both give you unmatched stopping power. However, I like the TCE Wilwoods better.
The 96 upgrade is another option,however with them after repeated high speed stops they will fade. I don't have that annoyance with my big brake systems.
