Brake question
Griswold,CT.
hey what's up guys, got a question i broke a couple brake lines over the weekend, and i wanted to replace both lines that run from the front to the back, but here is my question, as i was looking i saw the split in the back and up front i noticed a small box under the airbox where lines go into, so if i wanted to change the brake lines i would go from the split in the back to that box underneath the air box instead of straight to the master cylinder?
JustinSane
SHO OFF
PA SHO Shop
yes, that is correct, the lines from that to the master cylinder dont get rusty to often and should be fine.
